Seite 1 von 10
consumption of oil :o [Ölverbrauch 2.0 TDI]
Verfasst: 11. August 2005 17:52
von Calor y Sol
Is the well-read one in a Spanish forum that Octavia 2.0 TDI consumes a lot of oil, concretly they speak about 3 liters in 20000 km what is of certainly? Soon they will bring me this model. Those that you it have what result is it giving you?.
Once again thank you
Calor y Sol
Verfasst: 11. August 2005 18:57
von TDI-Schrauber
Hello!
In fact, older 2.0 Engines consums a lot of oil (up to 1l / 1000km). This is caused by wrong mounted piston-rings (upside down) so the oil is wiped up instead down.
volkswagen tried to point away the responsibility but several experts explained that a modern engine does not consume up to 1l oil within 1000km. an consumption of 0,1 - 0,3 l per 1000km is normal.
3l within 20000km is tolerable.
BYE
TDI-Schrauber
Verfasst: 11. August 2005 19:08
von Calor y Sol
Thanks to answer, since in Spain I do not have where to make consultations on the Skoda Octavia, a car that very is not known here.
Thanks you very much
Verfasst: 12. August 2005 16:13
von duke
hola calor y sol,
pues mi opinion es, de que 3 litros son un poco mucho. el primer litro heche a los 14.000 kilometros. importante es tambien como conduces.
saludo
duke
Verfasst: 14. August 2005 19:20
von murre
hi
i had the same problem with my new car. after only 6000km i had to fill up 0,75 liters oil.
i was totally surprised by the high consumption.
is this typcial or should i contact skoda?
thanks
alex
Verfasst: 17. August 2005 21:00
von alfredi
habe nach 20.000 km ca. 0,6 l nachgefüllt.
Gruß Uwe
öl öl öl....
Verfasst: 22. September 2005 20:54
von murre
hi leute,
ich habe mittlerweile (13600km) schon zweimal öl nachfüllen müssen. jeweils ca. 0,7 l!!!
hat jemand von euch ähnliche verbräuche??
mein skodahändler sagt, es sei normal - für mich bei einem literpreis von 22 EUR nicht nachvollbar....
danke
alex
Re: öl öl öl....
Verfasst: 23. September 2005 07:46
von Echo
murre hat geschrieben:hi leute,
Nach 16000 habe ich auch schon 1,6 l nachfüllen müssen. Mein Kollege liegt in Ähnlichen Regionen. Das scheint also normal zu sein.
(2.0 TDI)
Verfasst: 23. September 2005 08:35
von Crossbaer
My 2.0 TDI needs 0,75L Oil for 3500Km. In my point of view to much. But I remember our Audi A3 1.9 TDI which needs 1.0L for 2000Km. The problem is that Longlife oil is much to expensive...I payed 22€!! :motz: for one Liter (Esso Petrol station).
Crossbaer
Verfasst: 23. September 2005 08:58
von Tamiya
Why do some people still pay 22 € for 1 liter longlife oil at their local dealer? There's the possibility to buy the VW/Skoda released Castrol longlife oil in internetshops or at eBay for less than 10 €.
You can spend the spared money to go for lunch with your girlfriend/wife
Best regards
Tamiya
