Licht signal führ das radio - aber von wo?
Re: Licht signal führ das radio - aber von wo?
yamaha06 hat geschrieben: Was ist der Unterschied zwischen Taglicht und normalem Licht?
Beim Tagfahrlicht ist die Instrumentenbeleuchtung (normaler Weise) komplett aus und die Leuchtanzeigen werden nicht gedimmt, damit sie am Tage besser erkennbar sind. :wink:
jakob
Beitrag von jakob »
But not in Denmark - the light is on.
(The TFL is installed by Skoda before delivering the auto)
/J
Octi 1 1.9 TDI Combi 66kw
jakob hat geschrieben: (The TFL is installed by Skoda before delivering the auto)
I say, it's not correctly installed! The Control-Panel lights have to be OFF, when only the daylight is on!
jakob
Beitrag von jakob »
Hmm.. The car was delivered with TFL from factory, so it´s not going to be changed.
Where to find the signal then?
/J
jakob
Beitrag von jakob »
And no-one has any idea??
/J
If always all lights on, you have no signal to use.
Again:
The control-panel-lights have to be switched off if the daylight is on! Your dealer has to correct it.
Cause they are always lightning too, you have no chance to connect a signal, if the lights are switched on; cause all lights always on. :roll:
Greez
jakob
Beitrag von jakob »
I just thought that I could find the signal somewhere on the backside of the light-switch.. But I haven´t got the complete wire-scheme for my Octavia, so I´m only guessing.
Anaway - thanks all :-)
/J
